Hello, a report output (of a given spreadsheet) that is required by public sector in United States depends on proprietary software Microsoft Excel and fails to be generated with LibreOffice. This is an incompatibility in LibreOffice, but how and what exactly is the problem that it cannot correctly run the report? The effect is that freedoms are limited and Microsoft Excel (or any alternative vendors’ industry-approved proprietary software) is required to generate this report.
Background info on what this is:
When submitting building plans to regional government in United States there is often a required report “Manual Joule” describing heat loads that can be generated by a spreadsheet of the ACCA organization. Web search “acca manual j speed sheet” to find the downloadable resource from ACCA website.(1*) The report has to do with heat load in built structures and is dependent on proprietary information in a printed reference book “Manual J”; On read of the Manual J reference book it tells the reader to use any ACCA-approved software to generate the report. Among the many ACCA-approved proprietary software packages from private sector companies there is also allowed to use the ACCA-provided Manual J Abridged Edition Speed Sheet spreadsheet with Microsoft Excel. Great, right? We could use LibreOffice Calc and preserve our freedoms? No, unfortunately, LibreOffice Calc is not compatible with Excel for this document and the report fails.
I have just completed this process myself as owner-builder for a home, and after many hours of confusion I did realize that the report generation is broken with LibreOffice Calc.
My question and for a discussion: Where is the formula or code that does the work? What exactly is the incompatible feature or method?
I can provide a more complete example with data inputs used on my home permitting process, or refer to some walk-through of what data is suitable for entry to generate a report in Excel. Initially I will just refer to the original document as that is the most trustworthy (and not me asking others to open an interactive document).
Links:
1*: “MJ8ae 1.28 27DEC16.xls” Downloads - Public Files - ACCA
