greetings.
long time reader but first time poster. apologies for the longish post.
i’m trying to read data from a com port (com 7) from inside libre office (lo) calc using a python script. the data is captured on port com 7 on a windows 10 desktop from a digital caliper attached via an esp32 microcontroller (which is attached to the windows 10 desktop). i program the esp32 using the arduino ide and i can see the data on com port 7 via the arduino ide data window. if i close the arduino ide’s comm port window and open pycharm i can run a python script within pycharm accessing com port 7 and i can see the data. when i stop the python script from executing in pycharm and try to run a python script modified to work in lo calc as a macro i get a permissions error code (see bottom).
if i close all lo calc instances/workbooks that are open and go back to the arduino ide i can open the comm port window and see data again. close that window and go back into pycharm and run the python script and i can see data again.
as a side note, if any instance of lo remains open, neither the arduino ide nor pycharm are able to read data from the comm port (comm port busy error). i surmise that there is some bit of code that lo runs that spans all open instances (workbooks, documents, etc) that holds a connection open so long as any lo instance is open. close all lo instances and the port is released and other programs can use the comm port again.
i believe i worked out the bits in the python script that needed to be changed in order to port from pycharm and run as a macro under lo calc. i say that because when i navigate in lo calc to Tools-> Macros → Organize Macros → Python i can select the python macro i want to run and it allows execution with the execute button. but then i get a permission error. i have python installed local to the lo installation along with pip and pyserial local to it as well.
i must have omitted a step in the port to lo calc and was hoping someone could point it out. there may be other issues you see that i will run into after getting through the comm port access error. if so i would appreciate those insights as well. my skill level with python and knowledge of scripting within lo is fairly low.
here is the macro to read data from com 7 (10 times as a test). i’m not sure if the macro’s text will show as misaligned due to autowrap but here goes.
import serial
# removed unused irrelevant codelines by @karolus
sheet = doc.getCurrentController().getActiveSheet()
def concat_cell(args=None):
serialPort = serial.Serial(port="COM7", baudrate=115200, bytesize=8, timeout=2, stopbits=serial.STOPBITS_ONE)
serialString = ""
for each_number in range(10):
if serialPort.in_waiting > 0:
serialString = serialPort.readline()
try:
cell = sheet.getCellByPosition(0, each_number)
cell.setString(serialString)
except:
pass
g_exportedScripts = (concat_cell,)
here is the error i see when running:
A Scripting Framework error occurred while running the Python script vnd.sun.star.script:read-com-port-7.py$concat_cell?language=Python&location=user.
Message: <class 'serial.serialutil.SerialException'>: could not open port 'COM7': PermissionError(13, 'Access is denied.', None, 5)
File "C:\Program Files\LibreOffice\program\pythonscript.py", line 1057, in getScript
mod = self.provCtx.getModuleByUrl( fileUri )
File "C:\Program Files\LibreOffice\program\pythonscript.py", line 494, in getModuleByUrl
exec(code, entry.module.__dict__)
File "C:\Users\user1\AppData\Roaming\LibreOffice\4\user\Scripts\python\read-com-port-7.py", line 12, in <module>
File "C:\Program Files\LibreOffice\program\python-core-3.8.15\lib\site-packages\serial\serialwin32.py", line 33, in __init__
super(Serial, self).__init__(*args, **kwargs)
File "C:\Program Files\LibreOffice\program\python-core-3.8.15\lib\site-packages\serial\serialutil.py", line 244, in __init__
self.open()
File "C:\Program Files\LibreOffice\program\python-core-3.8.15\lib\site-packages\serial\serialwin32.py", line 64, in open
raise SerialException("could not open port {!r}: {!r}".format(self.portstr, ctypes.WinError()))
