Hi there!
I found a font based on Liberation Sans named UnB Pro, and I really liked the look of it, especially the light and black versions. I downloaded it from here: Marca UnB and I attempted to start using it in LibreOffice 3.6.
However, there is a huge amount of line space above the font. If I switch to another font like Liberation or UnB Office (which is just a renamed Liberation) then normal spacing above the characters is restored.
I then tested the same UnB Pro fonts in Scribus (http://www.scribus.net), and suddenly the spacing issue vanished! I can’t seem to figure out why Scribus “corrects” the font “spacing” while L.O. does not.
Is there some way to “force” L.O. to display the fonts in the same way? I have already set the style of the font to superscript with no zoom and negative line spacing, but that did not work.
I would appreciate any help in this regard. Thanks!
I use LibreOffice 3.6.2.2 (Build ID: 360m1(Build:2)) on Ubuntu Linux 12.10.
