Hi everyone,
I’m using Windows 10, Libreoffice 6.4.2 Calc.
i have changed some shortcut keys in “Customize - Keyboard”, and after that, i tried to reset it to default setting by “Reset” Button. But it does nothing, it only works when you are changing your setting.
So my solutions are :
1 - Backup (Save button) default setting of “Customize-Keyboard”, and restore when needed.
2 - Delete “User folder” named “4” in the : %appdata%\libreoffice (this thing will reset everything to default, it look like you just installed libreoffice.
The second way is not useful if i have changed much things in the Libreoffice setting.
So my question is : Is it a bug ? or it is a default behavior of libreoffice ?
Thanks in advance.
Generally, It is the Default behavior of Libreoffice.
