I.e. supposing I just want to put the word “or” in a formula: this gets translated automatically to the logical “or” symbol.
to insert reserved words literally in Math use quotes: { "or" }
or you may want
{ ital "or"}
Hope that helps.
If the answer helped to solve your problem, please click the check mark () next to the answer.
