Applying gradient to form's background does not appear to work
Using LO Version: 4.4.1.2 with OSX 10.10.3
I’m editing a form in Base which has a solid colour background .
I want it to have a gradient colour background so I do the following:
  • Edit Form Right click on the
    background
  • Select and click on Page…
  • Select transparency from the pop
    up menu on Page Style: Default
    style
  • Select Gradient from the list of
    bullet options (Note that the
    coloured panel changes from solid to
    gradient)
  • Click on Apply
    (note that
    the form’s background colour DOES NOT
    change at this point until I resize
    it)
  • Click on OK close the form - electing to save the background
    gradient changes before closing
  • Open the form and see that the
    background is unchanged and still
    solid
What am I doing wrong?
Have found a solution.
  • At the Page Style: Default style
  • Click on the fill drop down select Bitmap
  • Deselect tile - AutoFit should be
    automatically selected
  • Click on Import Graphic - NB For gradient fill ensure graphic file is such
  • Click apply
  • Click save
And on re-opening the form it has a gradient filled background.
Not ideal, but it works!
