Using LibreOffice version 6.4.3.2 on Ubuntu 20.04. I have purged and then reinstalled LibreOffice, but it still behaves the same.
this is a messed initial install of LibreOffice on Ubuntu 20.04 and for an unknown reason LibreOffice tries to call the old, deprecated help viewer instead of the default browser - the following procedure fixed that on my system (and others reported this also worked for them)
Completely remove anything related to LibreOffice
dpkg --list | awk '/ii/&&/libreoffice/{print $2}' | sudo xargs apt purge -y uresudo apt autoremove -ysudo rm -r /usr/lib/libreoffice/*
Reinstall
sudo apt install libreoffice(you may need to reinstall the offline help package as well, but can’t provide the correct package here, since you did not provide yourHelp -> About LibreOfficeinformation )
Note This procedures assumes you are using Ubuntu’s base repositories for LibreOffice --or-- Launchpad PPA’s for LibreOffice.
May be this will help you as well.
