Auto-capitalization of contractions does not work
The beginning of a sentence starts with a capitalized word except when the word is a contraction. Are there any fixes in the works for this?
may be you are affected by #tdf100778. If I understand the bug report right, then you should be able to get the auto-capitalization right if you untick Replace in Tools -> AutoCorrect -> AutoCorrect Options -> Tab: Localized Options -> Category: Single Quotes (But this has another side effect related to the appearance of the quotes)
Thanks so much. That did the trick.
Hello - please be aware of my comment (But this has another side effect related to the appearance of the quotes). This may be an issue in projects/documents, where design is a critical success factor.
Anyway :
If the answer is correct or helped you to fix your problem, please click the check mark (:heavy_check_mark:) next to the answer.
I’ll pay attention to any unforeseen consequences. I can always go back and change the setting if I need to.
