Impress - LibO 3.4.6 on XP/SP3
I write a text with bullets in a content field of Impress until the content field is filled up.
Autofit Text in the context menu is checked
Next I reduce the width of the content field.
Result: Font reduces to maintain the number of lines for each bulleted text written.
Expected result: Font is reduced as much as needed, number of lines per bulleted text is not kept constant but the content field is filled to it is maximum. With other words, the font is always kept at its maximum to completely fill the content field.
Question: Is this a bug or do I miss a setting?
Note: If I keep writing in the original size content window, font size reduces, number of lines are reducing and the content fields size is fully utilized.
Your help is appreciated!
