Base date calculation problem
Hello All. I’m new here and new to Base, so please be a bit patient with me. I am developing a database to help run my family farm. I have created a table for planting which is the problem now. I want to input the date something was planted, and have the database generate the harvest date by adding the # of days it takes a given plant to mature. I keep getting syntax errors. This is the sql code I have tried so far…any help will be appreciated.
SELECT
  "Plants"."PlantName"
, "Plants"."Variety"
, "Planting"."LocationPlanted"
, "Planting"."QtyPlanted"
, "Planting"."DatePlanted"
, "Planting"."TimeToMaturity"
, "DatePlanted" + "TimeToMaturity" AS "Harvest Date"
FROM “Planting”,
WHERE “Planting”.“PlantID” = “Plants”.“PlantID”
and ‘DatePlanted’ + ‘TimeToMaturity’ >= 'Current_Date
As I have not much time start here:
Above information is for the default HSQLDB. If you use another databese you may simply use DATEADD()
:grey_question:
And what is your DB?
Please take notice that Base is not a DB.
E.g. with Firebird it is
DATEADD("TimeToMaturity" DAY TO "DatePlanted")
TimeToMaturity = INTEGER for days.
I also found the use of INTERVAL
DATE_A + INTERVAL '1' MONTH
I have not tried this, and don’t see it in a quick scan of the docs for old HSQLDB, so it may be added later.
https://www.hsqldb.org/doc/1.8/guide/guide.html
By the way…
So first of all: what kind of DB are you intending to use?
As it is a DB for real (“production”) work, forget about embedded mode.
Use external, either Firebird or HSQLDB 2.7.
(post deleted by author)
