Hi,
I’m trying to import a DB that was originally created using Access 2010; after successfully creating the connection, at the very last step I get this error message:
“Decoding not supported. Please choose a CodecProvider which supports reading the current database encoding.”
The original DB is in Italian therefore there are some accented characters (I usually use encoding Latin1), so I am not sure how to proceed here to make Base read the DB with the correct encoding.
Any suggestion?
Thanks in advance
Lia
