Can anyone help interpret the error code I am getting. It is for a very simple single table database which works fine for a few entries; all saved records, close and reopens fine then after a another entry will then show the following when opening the data base file:
SQL Status: S1000
Error code: 40
S1000 General error java.lang.NullPointerException in statement [SELECT * FROM “ProductStock”]
