Base: How can I fix this case when to be parsed by LO and not HSQL Directly?
Hi All,
I have been trying get s table to display two records in the same result row using LO 4.1 and the embedded HSQLDB version. Sliderule provided a great example, but I want to be able to parse the sql with LO and not HSQL because I need to add variables to code. I thought I would try this as a learning experience. The last bit of code is this:
SELECT TOP 1 CASE
      WHEN MOD("F3"."TOTAL", 2) = 1
         THEN "F3"."ID"
      ELSE NULL
      END AS "COL1"
   ,CASE
         THEN "F3"."FruitName"
      ELSE NULL
      END AS "COL2"
   ,NULL AS "COL3"
   ,NULL AS "COL4"
FROM "FRUITS_ROWNUM_VIEW" AS "F3"
ORDER BY "F3"."TOTAL" DESC
It’s part of a larger view, but I traced the issue to the above section. The other parts all work fine by themselves as I broke it up and tested smaller parts. This is the full code of the view:
// FRUITS_2COL_VIEW
SELECT
	"A"."ID1"
   ,"A"."FruitName1"
   ,"A"."ID2"
   ,"A"."FruitName2"
FROM (
   SELECT
	   "F1"."ID" AS "ID1"
      ,"F1"."FruitName" AS "FruitName1"
      ,"F2"."ID" AS "ID2"
      ,"F2"."FruitName" AS "FruitName2"
   FROM "FRUITS_ROWNUM_VIEW" AS F2
   CROSS JOIN "FRUITS_ROWNUM_VIEW" AS F1
   WHERE ("F1"."TOTAL" + 1) = "F2"."TOTAL"
      AND MOD("F1"."TOTAL", 2) = 1
   UNION ALL
      SELECT TOP 1 CASE
               THEN "F3"."ID"
            ELSE NULL
            END
         ,CASE
            ELSE NULL
            END
         ,NULL AS "COL3"
         ,NULL AS "COL4"
   ) AS "A"
WHERE "A"."ID1" IS NOT NULL
   AND "A"."FruitName1" IS NOT NULL
As you can see, I added in AS “COL1” and AS “COL2”, trying to follow another format in a different post about this:
They mention being able to do this in LO without needed HSQL to parse it directly.
The error that I get with the trouble section is the following:
SQL Status: HY000 Error code: 1000
syntax error, unexpected $end,
expecting BETWEEN or IN or
SQL_TOKEN_LIKE
I hope someone can help me get this section working with LO’s parser so I can add in variables.
Thanks,
Jon
After more studying, it appears that Base only supports TOP in SQL mode rather than processing it directly. Is there a way to return only one record in a Base friendly way?
I did it, but it’s really a bit of a hack, in my opinion. If anyone has a better way of doing it, please let me know as I know have a lot of sub-select statements going on, so the runtime of this on a large database must be huge. The solution is to replace TOP with MAX as follows, in case anyone needs the answer to this:
SELECT CASE
         THEN "F3"."ID"
      ELSE NULL
      END AS "COL1"
   ,CASE
      ELSE NULL
      END AS "COL2"
   ,NULL AS "COL3"
   ,NULL AS "COL4"
Where "TOTAL" = (SELECT MAX("TOTAL") FROM "FRUITS_ROWNUM_VIEW")
Cheers.
SELECT
     CASE
        THEN "F3"."ID"
     ELSE NULL
     END AS "COL1"
  ,  CASE
     ELSE NULL
     END AS "COL2"
  ,  NULL  AS "COL3"
  ,  NULL  AS "COL4"
LIMIT 1
By using LIMIT 1 at the bottom, this Query will work for you, whether using the LibreOffice Base Parser, OR, if the Query is passed to the database engine ( HSQL 1.8.1.10 ) directly.
Sliderule
SELECT
     CASE
        THEN "F3"."ID"
     ELSE NULL
     END AS "COL1"
  ,  CASE
     ELSE NULL
     END AS "COL2"
  ,  NULL  AS "COL3"
  ,  NULL  AS "COL4"
LIMIT 1
Sliderule
