[Base] How to add a report and formatted fields in it using a macro?
I use LO 4.3.3.2 in French on Debian Jessie also in French and try to add a report and formatted fields in it using a macro.
I used createunoservice function to create my objects but it didn’t work. That is to say I get no errors but it doesn’t work. I ask this question everywhere on Internet and get no answers. I don’t know whether it is difficult or not to do.
Here is what I did:
REM  *****  BASIC  *****
Option Explicit
sub createReport
dim oConnection as object
dim oReportsDocuments as object
dim oReportDesign as object
dim oField as object
oConnection = ThisDatabaseDocument.DataSource.getconnection("","")
oReportsDocuments = ThisDatabaseDocument.ReportDocuments
'trying to create a new report
oReportDesign = createUnoService("com.sun.star.report.ReportDefinition")
oReportDesign.setPropertyValue("ActiveConnection", oConnection)
oReportDesign.Command = "Table1"
oReportDesign.Name = "monrapport"
oReportDesign.caption = "legende"
'oReportDesign.setparent(oReportsDocuments)
'trying to add a new formatted field
oField = createUnoService("com.sun.star.report.FormattedField")
with oField
    .name = "field1"
    .DataField = "field:[champ1]"
    '.positionX = 14000 REM marche pô (pas d'erreur mais pas pris en compte)
    '.positionY = 0 REM marche pô
    .width = 2000
    .height = 500
end with
oReportDesign.detail.add(oField)
'trying to add it to the reports
oReportsDocuments.insertbyname("monrapport", oReportDesign)
end sub
Thanks for your help.
Is the line at the end, oReportsDocuments.insertbyname, looking for the object type "com.sun.star.comp.dba.ODocumentDefinition"? That is the object type you would receive by the getByName method. Not sure how that fits with the main object you are editing, "com.sun.star.report.ReportDefinition" Alternatively, what if you filled in more of the properties of oReportDesign.
