I am attempting to write a macro that uses SQL to query a table and need to determine if there is a “Not found” result.
I copied the routine at handle runtime error sql macro
but am getting a run time error.
oContext=CreateUnoService("com.sun.star.sdb.DatabaseContext") 'One service for all SQL processes
oDB1=oContext.getByName("DogDBTest1") 'get the database
oConnection1=oDB1.getConnection("","") 'establish connection to database
oConnection1.ResultSetType = com.sun.star.sdbc.ResultSetType.SCROLL_SENSITIVE 'added to allow for NRF
oResult1 = oStatement1.executeQuery(sReadReg & sRegistryID)
CursorTest = oResult1.first
If CursorTest = "False" Then
MsgBox (sRegistryID & " Not Found"
Else
While oResult1.next()
MsgBox (oResult1.getString(1) & "=String(1) " & oResult1.getString(2) & "=String(2) " _
& oResult1.getString(5) & "=String(5)"
wEnd
yada…
Run time error says "Property or Method not found: ResultSetType
Can anyone see errors in code or point me to alternate solution to determine if no record was found
I also attempted to use ifNull solution but that didn’t work either
