Base Writer Mailmerge Issue
LO 7.1.2.2 Win 10 Hsql2.51
Hi,
Putting together a mail merge from a query to a writer document which works okay, however I am a little puzzled about Writer telling me there are 17 pages whereas the document actually only contains 9 address headers and so does the query.
So the number of records match but am at a loss where the 17 pages come from and what the (p1) means. Have to admit not familiar with writer.
Is this normal or a bug ?
Thank you
Sounds as if it is your formatting. Look what is on each of the pages. Can’t see you results but seems like the original design overflowed to a second page when the merged information appeared. I believe the p. 1 means page 1 - multiple pages for each merged document. Again back to formatting.
@Ratslinger , thanks for the quick response. I have applied no format at all, just opened a blank file, nominated the datasource and pulled down the field headers to create an address block.
Also weird if I want to edit the document by inserting a space between a couple of fields I end up crashing. Only resolve is to recreate the doc
Have nothing further right now. Do not recall at this time having had that issue.
Edit:
Just did quick test with three records. All is OK unless I save all as one document. Then the three pages registers as 5 but only seems to print as three. Possible a bug although on my system it actually shows (lower left on status bar):
Page 1 of 5 (Page 1 of 3 to print)
This on Ubuntu 20.04.2 with LO v 7.1.2.2 from TDF
Yes the merge is generated into a single document. I can live with that issue. But alas, after running the merge, closing the db and restarting, the db is no longer registered. Is there a way of re registering the db if not registered, sort of conditional register ?
If your DB is no longer registered, I have not sen this happen simply by doing a mail merge. Something else may cause this such as moving the Base file.
You can add/delete/modify Base registrations. From menu Tools->Options. Then under LibreOffice Base->Databases on the right are the registered databases with buttons to make changes.
Thank you @Ratslinger
