Hi everyone.
I am using Writer to create forms. In these forms I want to create check-boxes to be ticked by my clients.
Just wondering what the best way to do this is?
Currently I am using the “rectangle” shape found at far left of the bottom “shapes” toolbar (or whatever you call it) then simply resizing it into a small square.
However, copy/pasting this shape doesn’t seem to work- I would like to be able to make one, then copy/paste it into different lines, saving time and ensuring each square is the same size.
Thanks to all.
to the left and, karma permitting, upvote it. If this resolves your problem, close the question, that will help other people with the same question.
