Well I use local bibliography database and have set the bibliography entry style inside square brackets [12].
The problem is the entries appear like [1. instead of the right bracket there is punctation. Is this some file format issue, could this be solved without manual edit or do I have to create new documentation ?
Also if the only option is the last one, how to export the bibliography database from document ?
