I have a simple scenario and I am unsure why it does not work, other than I really do not understand how LO binds or associates templates to files. The fact that the template is still identified in the properties section of the file gives me hope, but I am sure LO does not just try to associate the file name there and is using more garbage to ‘make sure’ the correct template will be applied (e.g. fullpath, etc.) Therefore, since it obviously does not work, may I ask what is the proper procedure to use, since this is not documented anywhere? I tried:
- zip up my .odt file on old system
- unzip .odt files on new system
- export temlate and copy the .ott file to new system
- import template file into new system
- make a change to template (change heading font color), save template, close
- open a file that uses the template on new system, check properties (correct template name is there), template update is ignored (BUG)
Please explain if this is supported or not and why.
