OS on Virtualbox : Ubuntu 18.04
When I try to build the libreoffice on Ubuntu 16.04 and Ubuntu 18.04, they both occurred “Ant does not work”.
I check with ant -verbose, then get error message :
Apache Ant(TM) version 1.10.3 compiled on July 19 2018
Trying the default build file: build.xml
Buildfile: build.xml does not exist!
Build failed
More information about ./autogen.sh’s error message :
checking for ant... /usr/bin/ant
checking if /usr/share/ant/bin/ant works... configure: error: Ant does not work - Some Java projects will not build!
Error running configure at ./autogen.sh line 296.
Somebody know how to create/write the Buildfile ?
