Calc: Cell selection (using shift and arrow key) unintentionally jumps to upper left corner (A1)
Whenever I shift any cells with Shift-Del Shift-Insert from one position to another and subsequently try to modify the selected area with any Shift-ArrowKey the selected area switches as if I had entered Shift-Ctrl-Home (Shift-Strg-Pos1) or had clicked in the upper left corner of the sheet with Shift-key down.
Example (how to reproduce it):
  1. select cell C3 (doesn’t matter if it is empty)
  2. press Ctrl-Shift-Del
  3. move focus one cell right i.e. press arrowKeyRight (focus is now on D3)
  4. press Ctrl-Shift-Ins
  5. if you try to enhance the selection from D3:D3 to D3:D4 by pressing Shift-ArrowKeyDown, the selection switches to A1:D3)
    The only way to avoid this unwanted behavior is to temporarily click/select any other cell (e.g. B2) after step (4.) before reselecting D3. After that maneuvre, pressing Shift-ArrowKeyDown works as expected and the area D3:D4 is selected.
I don’t know wether this is a bug or a feature. If it is a feature, I wonder for what purpose. Anyhow I would be very thankful for any hint, how to solve this.bug or disable the ‘feature’.
Thanks a lot
{using Version: 6.2.8.2 (x64) Build-ID: f82ddfca21ebc1e222a662a32b25c0c9d20169ee}
{Operating System CPU-Threads: 4; BS: Windows 10.0; UI-Render: Standard; VCL: win;
Gebietsschema: de-DE (de_DE); UI-Sprache: de-DE Calc: threaded}
Can you please add some information on Operating-system, and if it is Linux used Distribution, Desktop (kde, gnome, xfce…) as your obsevation may not be present everywhere…
Definitely, the details about environment are essential. In addition to using an obsolete version (6.2 was 5 major versions, more than two years, ago), the observation about keyboard shortcut behavior is usually very system-specific, and it may be just some OS/desktop key handling that converts some sequence into something else. I do not repro the observation using 7.3.0.2 on Windows 10.
THX for your hints! I’m currently upgrading to version 7.1.8. but I have little hope, this will change the game as the reported behavior annoys me (afaik) since I switched from excel to calc.
As soon as 7.1.8 is up and running I’ll tell about the results
Just to show some confusion in the steps: doing this on C3 (both empty, and containing data) for me enters the cell’s in-place edit mode (i.e., blinking cursor appears inside the cell); is that what you experience? Because it seems that you might see something else - could that be something specific to localized shortcuts maybe?
Sorry sorry, I apologise it’s just Shift-Del Shift-Ins (without Ctrl).
Meanwhile 7.1.8 is running and shows the same behaviour as the older version.
Ctrl-X Ctrl-V (instead of Shift-Del Shift-Ins) shows the same unwanted behavior
Ah - it shows how much attention is needed when you provide steps, and how important it is to perform your own steps after you typed them, to check yourself. Yes, I do see something using Shift instead of Ctrl+Shift in the steps (it selects A2:D3 in my case); of course, it is a bug, and needs a bug report.
Thanks a lot and have a great day!
For me Shift+Del cuts and Shift+Insert pastes, i.e. same as Ctrl+X and Ctrl+V. If I do Ctrl+Shift+Del it just deletes while Ctrl+Shift+Insert does nothing.
Either way, if I paste in the new cell then use Shift+Arrow keys I get:
  • Shift+Left = select to A1
  • Shift+Right = select to B1 (excludes first column)
  • Shift+Down = select to A2 (excludes first row)
  • Shift+Up = select to A1
  • Ctrl+Shift+Down = Select to beginning of row
  • Ctrl+Shift+Right = select to B1 (excludes first column)
  • Ctrl+Shift+Left = no change
  • Ctrl+Shift+Right = no change
This looks like it might be a deliberate function. If you keep the selection and use the Shift+Arrow keys it will reduce the selection as normal after the initial selection.
NB. If you click Shift+Backspace it “Deselects the current cell selection without deleting contents.” So then you can use the Shift+arrow keys normally
It is already reported, please add there your comment.
EDITING: After Cut and Paste (Shift-Del Shift-Ins or Ctrl-X Ctrl-V) Shift-ArrowKey results in a jump to cell A2
