In Calc I can manually drag a chart legend box to a desired location. However, if I save and then re-open the file then the legend box returns to one of the default positions (Left, Right, Top, Bottom). This seems to be because, even after dragging the legend box, one of these default positions remains checked. I can’t find a way to uncheck the defaults.
LibreOffice offers more curve fit options than OpenOffice so I’d like to switch but not with this problem. If there isn’t a fix in the current version, is there a previous version without this problem?
v. 4.4.1.2
Windows 7 x64
Thanks,
Don C.
