I am wondering if there is a way to format cells to display the exact input I’m putting in unless it is a formula?
So, I have a block of cells that is usually filled with a formula. Sometimes, I do want to manually put in values and just want that value to be displayed. However, the input is not necessarily a number, but something like “8+” or “9-10”, which conflicts with all of the formatting options I have found (Except for text, which in turn suppresses formulas).
All of the formulas output decimal numbers, if that helps and/or makes a difference.
Thanks for the help!
