Hi Guys,
I couldn’t think of a descriptive title, so I posted the problem
Sorry to pester you again, another problem I need to fix asap, caused once again I believe by the default settings of LO.
Using Calc spreadsheets I need to paste in scores out of ten in this format… 7/10 i.e. with a forward slash.
When I do so at present, this format gets changed as variations of the number. 41921.00
Note: Decimal digits are set to 2 after the point by me.
As I have no idea what this format represents I don’t know how to put it right or what to search for.
Can someone help?
Thanks
Version: 4.2.1.1
Build ID: d7dbbd7842e6a58b0f521599204e827654e1fb8b
