Previously I reported then I followed up that I could not reproduce it. Since then I tried with variious files, and I can reproduce it at will.
I can also report that when this happens LibreOffice consumes a huge amount of memory.
I recreated the file on Fedora Core 23, LO 5.0.6.2 where it works perfectly, then copied the file to Fedora Core 24, LO 5.1.5.2 where is has the problem. If you give me enough karma to upload the files, I will attach the file, as well as a screenshot of htop showing the CPU usage.
