I use last LibreOffice release on Windows 8 64-bit.
I have to import a csv file with decimal numbers.
When i open the csv with Calc, the number are stored (not only displayed) with less decimal than the source.
Example:
627511,07554523856 (csv source file)
627511,075545239 (value stored in .ods file cell)
The only way i found to store the whole numbers inside the cells is importing the csv as text.
But when i use the function “VALUE” to convert them as number, the same rounding problem appears.
I realized that the same is happening when i copy a single number (ctrl+c) and i paste it inside a cell (ctrl+v).
What’s is going on?
Thanks!
I want to copy it and paste in some browser filter)
