Would it be possible to do a command line export to pdf of an excel file with the cells , something like a grid view.
Something like a option in the command line export
libreoffice3.6 --headless --invisible --convert-to pdf sample.xls (–with-grid)
It’s a page style option to print the grid or only the data. Is that option set in you xls files? If not, you may need a macro to modify the file before exporting to PDF:
(Comment → Answer for Resolution)
@tohuwawohu writes:
