Instead of printing smaller, 2 or more sheets on a page, I would like to print a page on a 2x2 or 3x3 array of 8-1/2 by 11. For example I have a periodic table that I would like to post on the wall for my class.
With Writer, you can export as PDF, then with your PDF reader print as a poster.
Better if you work with Draw and set the final desired size page, so no need to scale when printing.
Add Answer is reserved for solutions.
Press add a comment below the question if you want to add more information; also can comment an answer.
