Under the “Slide Transition” tab, below where you select that you want to advance the slide automatically, there is a field to enter a number of seconds that the slide will show before advancing. The maximum value that seems possible to enter is 99.99 seconds. Any larger number will be automatically reduced to this value.
Can this field be customized to accept larger amounts of time? Would someone who understands the programming and code and such be able to explain how to do so in steps that a somewhat crafty layperson could follow? Maybe a line or two of code could be changed to accommodate minutes and seconds, or even just a larger number of digits so that I could put in up to 1000 seconds or so.
Thank you kindly
