I am trying to use a CASE statement in a query. I have this snippet of SQL code
SELECT Case
WHEN “Name” = ‘Familj’ THEN ‘On’
WHEN “Name” = ‘Jessica’ THEN ‘On’
WHEN “Name” = ‘Johanna’ THEN ‘On’
WHEN “Name” = ‘Lennart’ THEN ‘On’
WHEN “Name” = ‘Leriks Data’ THEN ‘Off’
WHEN “Name” = ‘Ludvig’ THEN ‘Off’
WHEN “Name” = ‘Marie’ THEN ‘On’
WHEN “Name” = ‘Molly’ THEN ‘Off’
WHEN “Name” = ‘Snö Data’ THEN ‘On’
Else ‘Off’
END as “Visible Text”,
“Visible”,
“Name”
FROM “tblOwner”
it works fine in direct SQL window but when I try to insert this SQL code into a query it says SQL error??? The result is that i can’t create a query for this. Does any one know a way to create a query?
