Cell format problem
Hi
I cell format problem in Calc. When I enter numbers 1 or 2 or number 13 or higher the numbers appear as they should. Numbers 3 to 12 get changed to say 3-1 or 9-12 etc. When I enter say 15 I can see it starts as 15-1 but changes to 15 as I want it. There is a condition somewhere but where and how do I change it? I only want a number to appear in the cell.
Using Libreoffice version 24.2.7.2 using Linux
Cells above the cell in question are formatted as 3-12 or 4-10 etc.
I have checked Format Cells.
  • In the Format Cells dialog, select the Numbers tab.
  • Ensure the category is set to Number or General, and not a custom format.
Tool Extension Manager.
  • Disable any recently installed extensions to see if they’re causing the issue.
Go to Format > Conditional Formatting > Manage…
  • Ensure there are no rules that could be applying the “22-1”.
Thank you in advance for any guidance.
In the menu Tools, is the option Autoinput checked? Try disabling it and let’s us know if it works better.
Hi, thanks for the reply. That did it!! Didn’t know about that option. Thanks so much. Have a nice weekend.
