The title says it all, I made the mistake of installing 32bit LO Fresh on my Main Windows 7 64-bit machine. The problem is, it is to slow. I then installed 64-bit LO to my other Laptop (Windows 8.1) that is a little more powerful (but not much more) and that LO Starts and runs much faster. So now I would like to get similar performance on my Main Laptop, hopefully by installing the 64bit version. Some may think there is no difference in the speed between them but I am willing to try because it is just way too slow.
They are both AMD A-8 Series CPU’s with plenty of RAM, so they both should be capable of running LO at similar speeds I would think. I can’t believe the speed difference, I almost Un-installed it on my Main Laptop until I saw how fast it is on the other.
So, can someone tell me the best way to do this? Don’t want to muck about my Favorite Laptop and have leftover Config files etc. that may affect the performance of the new Installed LO. Should I use the built in Un-install tool via Programs and Features, or use something like REVO UNINSTALLER? Or, can it be just installed over with the 64bit Version?
Thanks Convert22
