Hello everyone, I see this problem has been already posted with no results, so I’m posting again.
Using LibreOffice 6.2 (and after upgraded to 6.3), inserting a citation in Writer and then saving/re-opening it, it creates the word CITATION attached to the short word used to “call” it.
Anyone has a solution? Have a nice day everybody
EDIT 1: for compatibility requests, I’m obliged to use docx. formats and not others, and yes, it’s the same as the problem above
EDIT 2: I hope this analytics procedure helps understanding
1 create a citation with author, article type, year, url and short word as reference
2 save document and close it
3 re-open it and check the citation
4 instead of [short_word] as normal, it is written [CITATION ““short_word””]
EDIT 3: As per your request, I checked the same error when saving with odt format, and the error DOESN’T occur here, so in odt format there’s no error
