How do I go from a column format to a no-column format within the same document? “Insert > manual break > page break” does not disable the column feature, but acts globally on the document. Is there any way to do this?
Put the two groups of text in different sections, then apply the columns feature. See this link for more explanation.
You may try:
Cursor at the end of the last line in the column
Alt+Enter
Thanks. But it didn’t do anything. ts
Are 2 or more columns defined in the Default
page style?
