Comment Pop-Ups not working with freezed columns
Hello everyone,
I am trying to fix an issue I got with updating to a newer version of LibreOffice. It worked with a version that was like 2 years old.
Basically I used comments with an image as area. The idea is, that the user can hover over the cell and a picture with infomation is displayed. However this does not work when the column is freezed. The Pop-Up simply does not appear at all (you can barely see the arrow pointing to it in the right corner).
I attach a picture to demonstrate. A column is freezed. In one picture I hover over the comment in A, in the other the same comment over E.
LibreOffice Version is 26.2.0.3.
Thanks for any help :slight_smile:
Maybe in relation with
tdf#163513, Comment not showed above form buttons and lines when “Freeze rows and columns” is activated
