Conditional Formatting is not acting right
Need some help here, because I don’t know how to do what I want to do.
As always, thanks to everybody that helps out.
I"m using LO 25.2.1.2. I’m trying to set up conditional formatting.
I have an array 4col X 72 rows (A25:D96). Columns A-C are dates. I want to set up conditional formatting such that the entire row (all 4 columns are highlighted) if the value (date) in column B is the latest date less than today.
I have already tried setting up CF as follows: Format/Conditional/Manage/Add, and used the following: Condition 1: Formula is =$B25=TODAY(). But it doesn’t work. First thing that I noticed was that the FIRST equal sign is missing after I click OK. So, I’m wondering - why doesn’t it work?
So the formula should be $B52<TODAY() $B25<TODAY() and the Range should be A25:D96
Have you set a style?
Did you mean $B52 or $B25?
e.g.:
$B25=MAXIFS($B$25:$B$96,$B$25:$B$96,"<"&TODAY())
Worked Great! Thank you!
Why the last day before today? Are you using dates after today? If not, then ‘=MAX(B:B)’ will suffice.
000_shows row with latest datum_094919.ods (32.2 KB)
