Hi,
This is probably not the right location to post this, but it seems it should be noted somewhere. The discussion in the LibreOffice 6.4 manual starting about page 184 where I first noted it, made reference to dialog boxes opened in (Apple) “Styles and Formatting” that were not exactly like, say Paragraph in Properties, or Page where the dialog was labeled as just “Paragraph” or “Page”. In Styles and Formatting where a list of items is given, usually starting with “Default…”, if one of these items was clicked to select Modify or New, the click did nothing except change from blue to grey. Nothing would open the dialog labeled “Paragraph Styles:…” with essentially a double row of tab choices. I noted this should happen and wouldn’t.
It was finally then that I found the only place in the program where “right click” really required a two key “Control+Click” to do the operation, in at least OS-X 10.11.6 for Apple users. Perhaps it’s just my old remote track-pad, but I thought I would bring it to the attention of other Mac users. It’s the only thing where I banged my head against the wall over “right-click” not working.
Thanks
