[Running LO 6.3.2-2 on 64bit Arch linux]
[Addons: TexMaths v0.48, Zotero LO Integration v5.0, Wiki Publisher v1.2]
Except for the LO and add-ons’ versions numbers, nothing in that setup has changed in well other a year.
Hi:
Inside the Math formula editor (not the TexMaths editor) , kbd shortcut for copy (CTRL-c) does not seem to work well or at all. I.e. it’s erratic to the point of being completely unreliable.
Selecting portion of formula text inside the text editor and pressing key combination CTRL-c to copy, then CTRL-v to paste elsewhere in the same formula editor window or in a different one, results in nothing being pasted. Everything is as if nothing was consigned to clipboard about 8 times out of 10. I actually counted that other 50 or so attempts…
Doing the same by right-clicking and selecting contextual menus for copy and paste give identical results. In other words, kbd hardware is fine and works fine in any other app or terminal window.
As anybody seen that behavior and is there a workaround ? Cheers.
