How do I create a simple function that will sum a cumulative total in a column? That is every descending field will sum the total from the field to the left to the total in the field above.
Considering the values being in Column A and the accumulated in B, the formula in B will be = SUM(a$1:a1), and replicate to the cells below.
Good answer @Gilberto Schiavinatto, but the spaces inside the formula cause an error 501.
Please edit it without spaces as =SUM(A$1:A1)
Yes, I did not notice the collage. Google translator that places the spaces.
So please edit the answer so that others don’t make the same mistake
What is the “$” in the formula for?
Hello @jolive, this is not an answer but a new question.
If you want to comment on the given answer, then click on the button “add a comment”.
If the given answer solves your question, then please mark the answer as correct by clicking on the Checkmark icon on the left.
$1 = sets the value 1, does not change when replicating in the column below.
Here’s a example and tutorial on running total column in Calc:
