Create white letters
I want to create a Star of David, with a Gold Background, and then insert three Hebrew Letters in white, in the Star of David. The three Hebrew Letters are what is called, “The 72 Names of God”.
Can someone please help me accomplish this. It’s for a meditation practice.
Thanks so much.
IMHO, this is not a task for Writer. It looks to me like a graphics design project. Consequently, I recommend you do it in Draw.
The Star of David can be created either as a graphical shape with equilateral triangles and clipping or as a glyph (U+2721 STAR OF DAVID) in a text box.
Your Hebrew letters are contained in another text box.
You then arrange your objects to align them the way you want. And you can also group them in the end so that they behave as a single object when moved or resized.
Thank you ajlittoz for this feedback. I did use Draw and I have been able to bring in a Gold Star of David and type the letters in a Text box and color them white. Actually pretty easy now that I get the hang of it.
Thanks again for your point in the right direction.
Have a great day.
