Am running LibreOffice under Windows 10 22H2. The file format on all my Writer files in odt.
A screenshot of the result of clicking on a cross-referenced field is attached.
Having update to 7.6.x I found that all of my cross-reference entries when clicked-on, do not go to the Insert Reference point but instead open a list of Fields in the table of contents. I just downloaded 7.6.4.1 but found the same problem. Selecting GoTo on right-clicking an entry in the Fields list does nothing.
I have reverted to 7.5.9 - where the cross-reference function works just fine - and will have to stay there until this is fixed as I have thousands of cross-reference entries in the documents that I have created with LibreOffice.
I hope this can be fixed soon. Thank you very much.
Bill Cole
