Data Validity does not work with .xlsx format
Create a spreadsheet.
Choose a range of cells and go to Data - Validity - Allow (Choose List and add some values).
The dropdown works fine in the current session, but if you save and close the file and open again the dropdown is gone.
This bug happens only if you save in .xlsx format, if you save in .ods everything works like expected.
Someone had some similar issue? Im using the version 5.4.0.3
Maybe the same that this bug report tdf#90104
