In LO’s top menu “View” is one of the options. The first choices in the drop down menu are either “Normal” or “Web.”
The default choice is “Normal.” “Web” is optional.
How may one make “Web” the default choice?
It is a property of your default template. See: Creating and Changing Default and Custom Templates. Set the view mode to Web before saving the template.
To show the community your question has been answered, please tag the best answer (
), and/or vote for any helpful answer. Else, please edit your question to add information (answers are for solutions only).
Hagar, Thank you for your wonderful, simple, and timely answer. Your kindness in clearing up this question is very refreshing.
Thanks @Bruce2, kind words really appreciated!
In addition for those finding this question: the underlying thing is that the view mode is a property of the document itself, be it for a template (for new documents), or for existing documents (that need to be saved with the desired view mode).
