Dependency issue while installing 5.04 on fedora 20
libgnom2vfs-2.so0 for libobasis5.0-gnome-integration.1586.5.04.2-2 rpm is missing.
The installation rpm was downloaded from libreoffice web site.
How to proceed?
Your first problem is age-old distro release. 20 died 2015-06-23. 22 is still supported but there’s no point, just go straight to 23.
After you’ve done that, make a new question if necessary.
Are you certain the missing dependency is libgnom2vfs
and not libgnomevfs
? It sounds like the required version of the Gnome Virtual File System (VFS) package cannot be located. Fedora 20 is quite old. The list for this library here does not list a (Fedora 20) version for the x86 or x86_64 architectures. Which architecture are you using?
