Is there anyway to get a “definition” option next to the “synonyms” option when right-clicking a word in LibreOffice Writer 5 (OS X yosemite)?
There is a full answer already in Q56971.
If this helps then please tick the answer ()
…and/or show you like it with an uptick (∧)
This is not quite what I meant, although it is some way there. I proposed a dictionary within the context menu such that the definition appears when you hover over it (identical to thesaurus). Copying into mac dictionary is cumbersome by comparison
Nothing to stop you from coding your proposal.
