Can anyone tell me the difference between the Quadratic transparency and the Square transparency in Draw?
I am currently using version 7.4.7.2.(x64) on a Windows 11 machine.
Are you sure you’re meaning Transparency? Aren’t you in fact talking about Gradient options?
There is no difference if the width to height ratio of the shape is 1 (circle, square).
Thank you LeroyG. I was applying them to a square. I see the difference when I apply them to a rectangle with different length and width.
See also: tdf#154071
