Currently if one changes the view mode (View → Normal/PageBreak), this change will apply to all sheets in a Calc document. Would it be possible to define the View mode separately for each sheet? There is a reason for this:
Let’s assume the user builds a page to be printed and it requires to see it in Page Break mode, so it can better format it. At the same time, on separate sheets other things are happening (helper tables/formulas, etc) which do not require printing, but where a normal tabular view would be more beneficial. As it is now, the user would have to permanently switch between the two view modes, based on the needs, which is not very productive.
This feature could be added as an option, so if some users wish to have the setting applied to the entire workbook, that would be their choice, but also for other users who need different views on different sheets should be able to do it so.
Thanks for your attention in this matter.
