Do I need to uninstall my old Microsoft Ofc 97 first?
Hi @technonot,
As described in the answer to another question, you do not need to uninstall Microsoft Office before installing LibreOffice – you may have both installed on your computer at the same time.
The only conflict described in release notes is with OpenOffice. So if OpenOffice is installed then remove it first and then install LibreOffice. But there should be no conflict using Microsoft Office and LibreOffice at the same time, as qubit explained.
