I have an issue with bullet points, appearing double as soon as you enter them before a specific section.
Steps to reproduce, also see test doc:
- Open new doc
- Put in some random lorem ipsem text
- Go in the middle of the text, hit 4x enter to create white space between (not shift enter which in other editors still keeps it part as a paragraph), but a regular enter as a new paragraph
- Type
* spaceright in the middle of the 2 paragraphs - Behaviour: 2 bullet points appear
This annoys me because the expected behaviour is (like with any other editor) to create a new line with a bullet point, just for that line and not mess with upcoming lines/paragraphs. So evertime this happens, I have to correct it back to the way I want to. It doesn’t just do this with Body Text, also Header text gets a bullet point.
I’ve read a lot of topics, but am unable to find my particular case.
Before I worked with Templates and the whole Style shebang and thought I messed something up there and haven’t been able to fix it with that. But after doing a clean install I noticed that it comes like that out of the box.
The only setting I’ve done after the install is in AutoCorrect settings to enable the 2 Bulleted and numbered list options onder T, that’s it.
My questions:
- Is this a known issue?
- Does anyone know how to fix it?
Version: LibreOffice_24.8.5 on Windows 10
I’ve enclosed a document with various testcases.
double_bulletpoints_next_section.odt (42.9 KB)
If more detail is required, please let me know.
