Why am I not able to downlow LibreOffice in my windos10 64-bit?
And what have you tried?
Download LibreOffice - Feel free
LibreOffice - Installing under Windows 10 / 11
When I want to downlead I am facing this problem:
Having problems downloading LibreOffice? Note that we do not provide technical support for installing or using the software. If you need help, please visit Ask LibreOffice.
But if your question is about downloading LibreOffice from our website, let us know: (1) Your operating system version; (2) Your web browser; (3) Error message(s) you see. Send these to download@libreoffice.org and we will try to help.
What you are describing is not a problem, but a general note on the LibreOffice website.
Select your operating system there and then click on “Download” to start the download.
The exact procedure for the download is described above in the link “Download LibreOffice”.
If you have Windows 10 and not windows 10S then:
- Open the Start menu, and click Settings.
- Click Apps on the left side, then click Advanced app settings.
- You should see a “Choose where to get apps” option. Collapse its drop-down menu, and select Anywhere.
If you have Windows 10S then download LibreOffice from the Microsoft app store
Yes, I do this and able do download
thanks foe helping​:smiling_face_with_three_hearts:
yes, I do same and able to download and install
thanks for helping​:smiling_face_with_three_hearts:
How to apply or add hyperlink in s specific content and an Inage logo?
When I am print the sheet which are created in LibreOffice then open chrome browser then hyperlinks are not working
As this is not related to the original question, can you please create a new question for it. Happy New Year, Al
